キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Problem handing EOF (End of File)
Hello Everybody,
I am new to Labview and I want to read one text file and do some analysis on it. For the same I have developed one .vi which is marking error code4, which I believe has something to do with EOF.
I would appreciate if somebody can help me solving this problem.I have also attached the vi file I am using.
Thanks & regards
Janit
0 件の賞賛
メッセージ1/5
2,802件の閲覧回数
Please attach also the data file, so we can try it here.
Cheers,
Paulo
メッセージ2/5
2,792件の閲覧回数
Please find attached one typical file.
thanks
janit
0 件の賞賛
メッセージ3/5
2,791件の閲覧回数
What is the while loop for.
It seems to me that your program needs to run only once. And the first time it works good.
Remove the while loop and run it.
Hope this helps,
Paulo
メッセージ4/5
2,788件の閲覧回数
Thanks for the help, it works.
thanks
janit
0 件の賞賛
メッセージ5/5
2,786件の閲覧回数
