Problem generating word report
Hello everyone,
I have been trying to generate word report lately but it never worked. At first it was a compatibility issue since I had labview 32bit while my OS is windows10 64bit, but I'm still facing the same problem even when I installed labview 64bit.
Here's a photo of the error message.
Thank you for your help!
PS: Generating excel file does work.
Message 1 of 8
(4,374 Views)
Hi Syrine,
You can use some example of local help of LV to see the reaction of the code.
Why you don't use error cluster ?
This tutorial will help you : Report generation
reagards,
Fred.
Kudos are welcome!Smiley Wink
Message 2 of 8
(4,352 Views)
Hi Fred, I tried other examples but it's the same problem again even with error cluster. I believe it is related the OS or Active X like it says in the message (Error -2147417846) and in that case i dont know what to do.
Message 3 of 8
(4,339 Views)
I think in this case you must find the description of the error code on the web like specified in the message.
But, send me in the first time the version 2015 of  your vi.
Fred.
kudos are welcome!Smiley Wink
Message 4 of 8
(4,331 Views)
You can use 32-bit LabVIEW with the report generation toolkit. Please upload your VI so we can run it.
Message 5 of 8
(4,325 Views)
Accepted by topic author Syrine
Hi Fred and Gregory,
I actually don't know what happened because I modified nothing on the block diagram but the vi ran perfectly fine.
Thank you for your help !
Message 6 of 8
(4,310 Views)
I am having the exact same issue with the exact same error message. Although this was marked as solved, no solution was provided. Any help would be appreciated.
Message 7 of 8
(4,131 Views)
Hi Sam,
That is a very generic error code, so the fact that you got the same one does not tell us much. Please start a new thread with a description of your problem and code.
Message 8 of 8
(4,120 Views)
