Problem during connecting the oscilloscope
It's not the same error at all as you can see by reading the description of it.
Why do you keep insisting on writing your own code? I use the same scope and with the driver, I was capturing waveforms in minutes? Did you even look at the examples that come with the driver?
Message 11 of 14
(762 Views)
I know but if we just remove the last component (VISA CLOSE) then the program will stop at the same step as the last time (at VISA read ). No I actually didn't find those examples. the drivers are allready installed on my computer so I didnt download it.
Message 12 of 14
(761 Views)
It's irrelevant whether or not the close is there. There is a big difference between a timeout error and the previous one.
The NI-VISA driver would have been installed but the scope driver would not have been. Did you read about instrument drivers from the link I provided? When the scope driver is downloaded and installed, open the example finder and go to Hardware Input and Output>Instrument Drivers>LabVIEW Plug and Play.
The easiest way to install the scope driver is from LabVIEW>Tools>Instrumentation>Find Instrument Drivers.
Message 13 of 14
(758 Views)
well , I will try it. thanks again
Message 14 of 14
(754 Views)
