06-03-2009 10:20 AM
解決済! 解決策の投稿を見る。
06-03-2009 11:20 AM
Hi chuck,
normally you only need to insert the starting vi and the dynamic loaded vi's. All other vi will be included automatically. As far as i know the application builder will change the names of duplicates.
Mike
06-03-2009 11:40 AM
Mike,
Thanks, your solution worked. I was trying to load all the files except the starting VI in the "Always Included" section under source files. When I left that blank and only included the starting VI in "Startup VIs" everything worked. Just curious what is a dynamic loaded VI?
Thanks again!
06-03-2009 12:29 PM
When I run my .exe file is it necessary to have the .ini file (configuration file) and the .txt file (used as a header for an output file) in the directory or are they compiled in with the .exe file?
Thanks!
06-03-2009 03:34 PM
Hi chuck72352,
you can call vi's dynamically if you open a reference to it with the "Open Vi Reference" function.
I'm not sure which ini and txt file you mean, but the Exename.ini will be created automatically with every start of the exe, if the ini is not present in the same folder.
Mike
