Problem at wiring Max Min into Image
Hello , so im trying figuring to resize the image .
So i got problem couldnt wire the max min to the image
Sincerly,
(3,098 Views)
Accepted by topic author Gabess
Hi Gabess,
did you try to switch this "Zoomfactor" property node to "write"?
(And did you read the error description in the context help when you move the mouse over the broken wire?)
(3,094 Views)
You have conected output max and min to an output of property Node .
And i already try to change it to write and its works .:)
Can you give the explanation why i should change to write ?
(3,088 Views)
Hi Gabess,
I guess you want to set (aka "write") the ZoomFactor: then you need to set that property node to "write" access…
(3,085 Views)
okay thank you
(3,014 Views)
