03-27-2018 05:33 AM
Hello , so im trying figuring to resize the image .
So i got problem couldnt wire the max min to the image
Sincerly,
03-27-2018 05:52 AM
03-27-2018 06:00 AM
You have conected output max and min to an output of property Node .
And i already try to change it to write and its works .:)
Can you give the explanation why i should change to write ?
03-27-2018 06:02 AM
03-31-2018 02:27 AM
okay thank you
