Pro-grammatically create a path when using Write Waveforms to a File.vi
How do you create a unique file name when using  Write Waveforms to a file.vi that is in a loop ?  I have that VI in a for next loop and want my file name to be unique to each iteration of the loop.  For example, the 1st iteration of the file might be c:\testing\filename1.dat  then next c:\testing\filename2.dat ..then c:\testing\filename3.dat ..etc..  How do you concatenate the file name w the loop iteration to come up w a filename that is unique w each loop?
thxs
(4,066 Views)
Accepted by Clint1000
Use Format Into String to combine the base filename with the iteration number to create a new file name.  So your format string could be filename%d.dat
Then use Build Path to combine the file name with your base path for the directory structure.
(4,065 Views)
Perfect..thank-you.
(4,045 Views)
A very tiny addition:
You might want to consider a number format specifier like "%03d".  This would pad with 0's and make all numbers 3 digits wide, which is handy when you want to sort by filename when navigating into the folder.
-Kevin P
(4,007 Views)
-Kevin P
Or maybe just use the built-in function that AQ wrote, located in the Advanced File Function Palette:
mcduff
(4,000 Views)
