06-13-2020 10:31 PM
I am using the front panel of a VI to print a 4x2 label that has a barcode on it. I am using the caption of a string indicator for the barcode. I am using the "free 3 of 9" font for the barcode font. The barcode runs horizontally. This barcode contains a part number (ei *ALY01320U*) I use a property node to enter the data into the caption of the string indicator. This works great and my scanner reads the barcode correctly. I need to have this barcode run vertically. However when I rotate the barcode vertically and print the label the scanner will not read it. Does anyone have a solution for this problem.
06-14-2020 11:03 AM
06-14-2020 08:06 PM
@GerdW wrote:
Hi cmachnowski,
use a 2DPictureIndicator to draw your barcode: use the Text function with your font.
Then you can easily rotate the image by 90°…
Very cool solution!
06-14-2020 08:41 PM
Thanks GerdW this works great.
