Printer Output
Hello! I'm trying to save an information generated through printer output. Everything works exept that I'm saving duplicate data. I've attached a correct and incorrect. I would really appreciate any help.. Thank!!!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(4,112 Views)
Hard to say without seeing any code.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(4,099 Views)
It looks to me like you are building strings by concatenating data into a shift register and printing the entire contents of the shift register at each step.
As vt92 said, post your VI.
(4,076 Views)
Accepted by topic author KowdTek
Hello Kowdtek,
As Ravens Fan said you are incorrectly concatenating the string with the shiftregister data, see the attched vi in which i simulated the incorrect data you are getting now. also post your code for more help..
(4,053 Views)
