Print to Adobe PDF with ANSI E Paper Size
I keep getting error mesage "The margins you selected are invalid. Printing cancelled" when I try to print block diagram to Adobe PDF with ANSI E as the paper size. Has anyone try to do this or figure out away to print to larger paper size?
(4,782 Views)
aderogba,
How are you trying to print the block diagram of your VI?  Are you using File » Print...?  Or are you doing this programmatically?  If so, what VI(s) are you using to print?
Jared S.
Jared S.
Applications Engineering
(4,744 Views)
Manually through File >> Print option. The printer I intend to print to ( that I selected) is Adobe PDF.
(4,718 Views)
You can print the block diagram to an HTML file first and then convert that to a PDF. To print the block diagram to HTML, you can follow the instructions in this article. Also, there's another forum post similar to this one which describes printing very large block diagrams: http://forums.ni.com/ni/board/message?board.id=250&message.id=7659&requireLogin=False.
Jared S.
(4,697 Views)
