Print a front panel in a file
I would like to know if there is any function or other way to print a front panel in a file (a picture file or a print file) in execution mode.
thanks
(2,418 Views)
You can use the Get Panel Image method. Place an Invoke node in your diagram, select VI as Vi Server Class and choose Get Panel Image as the method invoked.
You can also choose if you want to copy the visible area only or the entire panel.
Hope this helps.
Roberto
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(2,418 Views)
