Prevent the User Changing Table Columns
Hi all.
Hopefully this is an easy one.
I am using LV 2010, on Windows 7 Professional, and I've selected a System Table control. I want to allow the user to edit the table data and add and delete rows, but I don't want them to be able to change (i.e. add or delete) the columns. Is there a simple way to do this?
Zola
(2,531 Views)
Aha.
Right click on the table, select Advanced->Run-Time Shortcut Menu->Edit...
On the Default Menu, select Edit->Copy Entire Menu.
Select Custom from the listbox, then Edit->Paste.
Now delete the menu options you don't want.
(2,527 Views)
