Monitoring PLC networks using LabView
Is it possible to monitor S7-300 network of PLC's using LV ? if yes can anyone link me to the know-how?
(3,613 Views)
Of course it is possible
You have a lot of way to do this
1) Use a OPC server
It is teh more expensive solution, but the easier to make
2) use Modbus
The S7 is compatible with ModBus serial and TCP/IP
It is free but more complexe to make
you can use the consol connector with a adaptation.
I am not the PLC programmer but i think you have nothing to do in the S7.
The word 123 the read at modbus register 123 !!
But warning, the word are U8 and modbus use U16. So when you read n value you must be carfully when you extract values from the array.
The S7 is the same as the S37 so the connection is
PLC SIDE     -          PC SIDE (RS422)
1 - 1
7 - 5
3 - 5
2 - 2
or in RS485
PLC SIDE     -          PC SIDE (RS485)
1 - 8
2 - 3
5 - 1
Ingénieur d'Application / Développeur LabVIEW Certifié (CLD)
Application Engineer / LabVIEW Certified Developer (CLD)
(3,590 Views)
Does that mean, i can upload VI's to the PLC, if yes, please link me to any videos or documents.
(3,556 Views)
No, PLC's aren't running operating systems that are supported by any version of LabVIEW. What the previous poster was saying is you can communicate with many PLC's using different protocols, some that are "free" (no additional cost to buy, probably a lot of hours to develop) or not so free (various OPC solutions) that LabVIEW can communicate through. The PLC will still be running whatever programs it would normally, but you can read/set values, and display them in LabVIEW.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,554 Views)
And another question , if  i am using OPC, what kind of connection i will need ?
(3,551 Views)
if you use the LabVIEW OPC, you use a OPC CLIENT. So your connexion depend on the OPC Server that you use.
The OPC server is depend on Siemens.
(3,545 Views)
Sorry my answor was not complete
The siemens opc server accept to configure all conenxion that the PLC can accept.
So you must look what king of PLC you have and with what king of communication option you have.
(3,544 Views)
