Pressing the ENTER key in first tab --> a button in another tab is pressed?
Hi guys,
I am facing a problem. I have a tab with 4 different tabs. When I am in the first tab, and trying to change a control's value by pressing the Enter key, it suddently switches to the seconds tab and presses a button there.
Any idea how that happens? I want to prevent that from happening.
Thank you
(3,376 Views)
Post some code, I'm sure someone would take a look at it.
-Ian
(3,368 Views)
Sounds like you have the enter key assigned to some key navigation of another control. This is a general problem with the OK button of the system palette. Here is more information.
(3,365 Views)
Accepted by Klimovitsky
Check your tab order, and check that the control that's being activated doesn't have a key shortcut tied to it.
(3,354 Views)
Thanks.
Sometimes a search does not find the right post.
Thanks. The button that was activated had the Enter key attached to it in the key navigation.
I right clicked on the button>> Advanced >> Key Navigation >> and set the Focus and Toggle to None.
Cheers and thanks
(3,329 Views)
Been there, done that, will probably do it again next week. Smiley Very Happy
It's a tricky problem if you're low on coffee ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,323 Views)
