Press Push Button if time Elapsed
Raven....
The motor works perfectly, please dont go back to the other discussion and ask for the Modbus address.....
I can perfectly control the motor, this is not the question anymore..I can control RPM, start or stop the motro, read output voltage, current, temp. This subject is finished.
The question is how I can start elapsed time when I click the button and to stop after specific time...
Alexis
Message 11 of 15
(776 Views)
Hi alexis,
See my message #2
Message 12 of 15
(773 Views)
Hello GerW,
Always very helpful! I tried it but it didnt work..
Will try it again now.
Thank you!
Message 13 of 15
(770 Views)
Hi Alexis,
What "did not work"?
When you press the button the ElapsedTime is reset and starts over from t=0.
When the TargetTime has been reached the ElapsedTime? output goes from FALSE to TRUE, and using the NOT the output goes from TRUE to FALSE.
IMHO it's exactly what you need when you write:
Again (as already been asked in message #6) you need to write down all of your requirements in a clear way!
Spoiler
Programming starts with writing down requirements in a clear way, leaving no room for misinterpretations…
Message 14 of 15
(766 Views)
@Alexis_Koul wrote:
Raven....
Alexis
But that IS the question.  If you can perfectly control it in that message thread, then you need to apply the same principles of how to control it in this thread.  Yet you have a disconnect.  Literally.  You are not wiring your VI properly so that it can send the same start and stop commands to the Modbus Write.
Message 15 of 15
(751 Views)
