‎03-10-2008 03:36 PM
‎03-10-2008
06:32 PM
- last edited on
‎09-20-2025
01:07 PM
by
Content Cleaner
Check out this developer zone article...http://zone.ni.com/devzone/cda/tut/p/id/4633
As long as you are using the LabVIEW Professional Development System, you can integrate your source control into LabVIEW.
Rational ClearCase is the tool I am using, but I only have the Full Development system so it isn't integrated.
ClearCase is fine, but using it for LabVIEW without having the Professional Development system is a pain.
Message Edited by Troy K on 03-11-2008 10:33 AM
‎03-11-2008 12:51 AM
Hi Sima,
I ve used MS VSS with LV 7.1 externally.
Now, it gets configured into LV 8.5 seamlessly without any problem. ![]()
In general, MS VSS is enough unless & until there are so many development teams working across globally; because it is said that it has some serious problems with networks.
‎03-11-2008 10:00 AM
Thanks for the replies.
We've sometimes noticed that you have to refresh or go to Perforce and Get the latest revisions manually, even after you Check Out a file, which I thought would automatically get the latest revision. Is this normal? What buggy things happen for you in ClearCase or MS VSS?
Also, can you comment on the administrative side of either one? Perforce seemed pretty easy to install server-side, and hasn't required much administration so far. We are a small group, so we don't have a separate administrator for source control software.
‎03-12-2008 05:43 PM
‎03-12-2008
09:02 PM
- last edited on
‎09-20-2025
01:08 PM
by
Content Cleaner
Hi Sima,
If you want more information about Using Source Control Software with LabVIEW this is an awesome tutorial
Hope this information helps a little bit
‎03-13-2008 05:42 AM
Hi Sima,
We re also exploring the possibility of integrating TortoiseSVN in our company.
From the presentation we had a few days back, it appears to be encouraging to be integrated into LV itself. But, I m not so sure as of now.
I shall update here once we re thro' the entire process.
‎03-13-2008 07:12 AM
‎03-13-2008 10:28 PM
Hi George,
Thanks for the info. ![]()
I thiunk the power point presentation was not clear to me completely. ![]()
‎03-14-2008 12:26 AM
