Power factor graph
Hi EduU,
usually you should attach your tries (even with errors) before someone will give you a working solution...
But I'm so kind Smiley Wink
Message 21 of 27
(2,194 Views)
Whereever in the world you have seen such a power-scale?
What is the math behind it to (in limes) equal 1 to -1???
All you have is a phase angle! where the PF represents the relative real part of the complex power. BTW how does the powerfactor look like if your load (asume a motor) turns into a source (generator)?
However here we go
Greetings from Germany
Henrik
LV since v3.1
Message 22 of 27
(2,180 Views)
Yes, henrik you are right!
I know why but I couldn't made it in labview
could you attach your Vi, to 8.6?
I don't have the labview 2009 yet x(
Thanks!
and GerdW thanks for the example... for sure I'm not able to find it my self haha
I'm only a beginner!
Message 23 of 27
(2,168 Views)
hey Henrik Volkers
Could you attach this vi for me in 8.6 version?
or anyone can download it and convert to me?
Message 24 of 27
(2,145 Views)
EduU 写:
hey Henrik Volkers
" 一天到晚游泳的鱼"
labview@263.net
我的个人网站:LabVIEW——北方客栈 http://www.labview365.com
欢迎加入《LabVIEW编程思想》组——http://decibel.ni.com/content/groups/thinking-in-labview
Message 25 of 27
(2,133 Views)
Thanks jwdz ;)
Message 26 of 27
(2,130 Views)
So I the same type of issue with this, I have created the graph and the data to attach so that my raw data now fits perfectly onto the graph.
The issue I now have it putting that graph into a pdf report. Obviously when I convert the graph to image data it doesn't contrain the scale numbers that I have manually added for the 0,1, 0
I have converted the data as obviously you need the graph ideally to have 1 in the middle then have 0 at the top and 0 at the bottom but have it go minus -0.9 etc down. Anyway, i have solved the numbering, I just intersted to know if anyone has found a way of just taking a snap shot of an area of pixels on the front diagram, ie the area where the graph is and then converted that into an image to use on a report?
Would be very useful if anyone could point me in the direction of some code that does that.
Peter
Message 27 of 27
(1,480 Views)
