Possible compatibility between Arexx RA-1 Pro & LabVIEW.
Hi people.
This is my first time posting and also using LabVIEW. I'm currently undergoing my final year project. The task handed to us is to design the end-effector of the robot given to us and program it in order to pick and assort eggs by May 2012. The robot given to us is the Arexx RA-1 Pro. I'm exploring ways of programming to automate a process sequence. It's not possible by writing a C+ file and then compling and flashing the microcontroller to do so.
I'm looking to see if anyone has any idea how I can achieve a sucessful communication between the robot to LabVIEW.
The specification of the robot is;
  • Atmel ATMEGA64 8-bit AVR microcontroller
  • FT232R USB UART
  • 6 Analog Servos
Any help of direction where to go would be great. I have LabVIEW 2011 but I don't have the robotics edition. If I need to, please tell me.
Thank you,
F. Mahder
(3,137 Views)
You can certainly use LabVIEW to communicate between your MCU and your PC. You could communicate over Serial and use NI VISA. A good place to start might be the VISA LabVIEW help pages:
https://www.ni.com/docs/en-US/bundle/labview/page/using-visa-in-labview.html
If you have a search on the forums, a few people have done this and looking at some of their posts may be of help.
(If you were using an Arduino (based on AVR) there is infact a toolkit to make this process easier!
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019TmpSAE&l=en-US)
If you question is whether you can deploy LabVIEW code to your MCU, unfortunately this is not really possible. You can use the LabVIEW C code generator to integrate a LabVIEW algorithm into your C code but I am not sure you will be able to get hold of this.
https://www.ni.com/en/support/downloads/software-products/download.labview-c-generator-module.html
Nick
(3,115 Views)
Hi Nick.
Thank you for your reply. It's given me a general idea about where to go in terms of researching and finding out the best method of communication.
I would like to also ask secondly, that I have another robot. It's called the Robai Cyton V2. It uses the Actin-SE to communicate through the FT232 USB UART between the robot and computer. I was wondering if there could be a feature which also integrates LabVIEW with this software.
I'm sorry for the questions, I'm inexperienced in this field but I'm very keen to learn LabVIEW as a skill.
Thank you,
F.Mahder
(3,106 Views)
As long as your control chip can do Serial Comms, LabVIEW should be able to communicate with it. With regards to interfacing with the Actin-SE software, I can see on their website that they provide a C++ API. Depending on how this is distributed you may be able to call it from LabVIEW. If they provide DLLs, LabVIEW can call them.
I certainly wish you luck in your endeavour - hopefully you will find it to be a good experience!
Nick
(3,091 Views)
