Possible Bug with Waveform Graph
You can use the "Report to Moderator" function of the "Options" menu to the right of your post:
Ask the moderator to have an engineer look at the thread and if deemed necessary (which it seems to be), file a CAR (and post it in the thread).
Message 31 of 33
(1,322 Views)
Accepted by Hatef.fouladi
Hi all,
Thank you for bringing this to our attention. I have filed a CAR #567900 on this issue, and so R&D is aware of it. However, as mentioned by others earlier, it can be a lengthy process so it's best to use whatever workaround you can in the meantime.
Selene v.
Applications Engineer
Selene
Message 32 of 33
(1,236 Views)
thank you for your help
Message 33 of 33
(1,215 Views)
