‎12-18-2015 02:20 PM
Dear Jeff·Þ·Bohrer
could you explain more?! I did not understand whether do you agree with me that such bug exist for invert mood of graph or not ?
‎12-18-2015 02:28 PM
I've got to ask, what is invert "mood"? Do you actually mean "mode"? Or another word?
‎12-18-2015 02:43 PM
@Hatef wrote:
Dear Jeff·Þ·Bohrer
On the two graphs this property is different for the X axis scales. I believe that this explains the X axis range min and max properties you see being reversed as well. SOME COULD argue that min is min and max is max irrespective of the inverted scale. I would like some other input from the feature developers before I call it a bug.
‎12-19-2015 12:04 AM - edited ‎12-19-2015 12:08 AM
Yes my means has "mode"
sorry for my mistyping
English is not my first language
The bug is that.
suppose I want have a graph that x scale is inverted and start from 5 to 105 and I want to have 5 grid for this scale (every 20 digit one line of grid)
for this reason labview graph has bug and it is impossible to have suck graph in labview
because when you select start in range property node labview get different and false number for start instead of the digit that you give to start in property node
so if you want see the bug start to make such graph that I mentioned above ( you could not make it due to bug )
‎12-19-2015 03:28 PM
I did this in LV 2014 and did the following steps.
1. Drop a new waveform graph.
2. Type 105 in at the first number on the x -axis
3. Type 5 in at the last number on the x-axis.
I don't see a problem.
‎12-19-2015 05:10 PM - edited ‎12-19-2015 05:13 PM
ok now just create property node and select range for x scale in write mode and try to give some value to increment . you will be see that grid disappear and if you use property node again but this time in read mode of xscale range you will see that start value is different than what you give it.
so you could not adjust grid in this mode of graph
see my first commend and try to download vi that I attached you will see the bug there
‎12-19-2015 08:30 PM
I added a grab of data before, then a setting of the range, then a grab of the range after.
I'm still not seeing a problem.
‎12-20-2015 06:04 AM
indeed you find bug now . just run your code countinusly and try to change Increment and see what happen for grid and start value
‎12-21-2015 09:23 AM
RavensFan do you now find the bug ?! or still belive that there is no bug in
‎12-21-2015 09:31 AM
Many times, the code works just fine for me.
But there are some times when it loses the grid. For instance, when I change the increment to 30 or higher. But when I change it back to 20, the grids come back.
But then after I run the VI multiple times and lose it, I can't get the grid to come back. (Note that I don't use Run Continuously).
So I agree with you that something strange is going on there. The one thing I notice is that when the grid goes away, the "Start" part of the cluster becomes some other value that is outside of the range of the Min and Max. When the grid is able to come back, then the "Start" becomes a value within the range.
