Possible Bug with Searching in LV 8.2.1 crashes LV
I need confirmation on this bug that crashes LV.
After you have saved all of your work try doing the following on the files in this zip.
Opened project Untitled Project 2.lvproj
Opened untitled 2.vi
ctrl-f
Select Object >...>shared variable
find button
ctrl-f
select text
paste in the string "Variable1" without the quotes.
Find button
crash!
One time it threw a cpp
LVLog follows.
#Date: Thu, Oct 04, 2007 5:52:58 PM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 8.2.1
#AppKind: FDS
#AppModDate: 11/26/2006 17:59 GMT
.\panel\panel.cpp(2938) : DAbort:
$Id: //labview/branches/Europa/dev/source/panel/panel.cpp#72 $
0x00C0741F - LabVIEW <unknown> + 0
0x006C05D4 - LabVIEW <unknown> + 0
0x006C0A0A - LabVIEW <unknown> + 0
0x005883A1 - LabVIEW <unknown> + 0
0x0058BE3B - LabVIEW <unknown> + 0
0x0058C0B7 - LabVIEW <unknown> + 0
0x0055FBFC - LabVIEW <unknown> + 0
0x00C480A1 - LabVIEW <unknown> + 0
0x00C4A336 - LabVIEW <unknown> + 0
0x004CCB29 - LabVIEW <unknown> + 0
0x00565049 - LabVIEW <unknown> + 0
0x005B852C - LabVIEW <unknown> + 0
0x006C307D - LabVIEW <unknown> + 0
0x00C478BF - LabVIEW <unknown> + 0
0x00C484DD - LabVIEW <unknown> + 0
Message Edited by Ben on 10-04-2007 05:19 PM
(3,178 Views)
Does in 8.2.1, not in 8.5.
In 8.5, it also doesn't find anything.
Message Edited by Matthew Kelton on 10-04-2007 06:49 PM
(3,164 Views)
I also can confirm a crash on LV 8.2
(3,145 Views)
This was reported to R&D (# CAR 40UG1C3D) and was fixed in LabVIEW (version 8.5). Here is a link to the current evaluation software download for LabVIEW. Thanks!
(3,120 Views)
