Portability / Cross Platform Development
Hi All,
I need to write LabView instrument drivers, on a Win98 PC, that will
port to a Sun.
I read Chapter 29 in the G Reference manual, and I've downloaded App
Notes: AN006 and AN111.
If you can point me to any other docs, and/or share your experiences,
things to watch out for, etc. I'd be most grateful..
I also have access to some CVI instrument drivers that I could
import/convert to LabView. I've heard that there is a CVI Function
Panel Converter, but so far I haven't been able to locate any
documentation on it. Specifically, I need to know if the converted VIs
would be portable to the Sun platform.
I've downloaded AN080, but this describes using CVI to make a DLL that
LabView can call using VIs generated
by Codelink. But I don't think
this will help me because DLLs aren't portable to the Sun.
Thanks in advance for your insights!
Best Regards,
Mike T
Mike Tranchemontagne
Consulting Applications Engineer
TeraComm, Inc.
148 Main Street
Building A, 3rd Floor
North Andover, MA 01845
877-900-TERA (8372)
978-557-9490 (FAX)
603-598-4773 (Direct Line and Cell)
[See first answer for additional information]
(3,345 Views)
[Attachment(s) for question]
(3,344 Views)
Depends on the type of driver you will be writing. If it is written using
VISA then it most likely will be easily portable, if you are writing a LV
wrapper for a driver DLL than it will be harder. Perhaps in that case you
could write a CIN wrapper calling instrument driver DLL, then slightly
modify that CIN and recompile it for Sun.
Ask in info-LabVIEW listserver (http://labview.pica.army.mil/), there seem
to be more people using LV for Linux, so they might have some direct
experience.
Hope it helps,
Reinis Kanders
"Mike Tranchemontagne" wrote in message
news:394FE971.B4E62336@teracomminc.com...
> Hi All,
> port to a Sun.
> LabView can call using VIs generated by Codelink. But I don't think
> Best Regards,
> Mike T
> TeraComm, Inc.
> 148 Main Street
> 877-900-TERA (8372)
> 978-557-9490 (FAX)
ll)
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(3,344 Views)
