Populate a combo box from a txt file
Hi, I'm trying to populate string and value of a combo box from a txt file (Lista motori) but i don't get any result. Someone can help me please? Where do i make mistakes?
(2,200 Views)
Accepted by topic author tj1995
You cannot have duplicate values, so once you fix your datafile, here's all you need:
(2,173 Views)
@altenbach wrote:
You cannot have duplicate values, so once you fix your datafile...
I think the second column is not a unique id, but rather a property "Limite" associated to the motor.
So he may want to use a ring instead, and create a cluster array from the file, which he can index later to select the motor configuration:
Raphaël.
(2,166 Views)
Thank you guys!
(2,155 Views)
I never (ever!) use comboboxes in my code, so my first idea was to switch to a ring, then I noticed that one of the "values" is not numeric. It is not clear if that was just a column header (language!) and that we can assume that all other values are numeric.
If we want the column headers as captions for the elements, here's what I would do. No FOR loop needed!
(2,136 Views)
could please save it for 2018 version.
I am using 2018 LabVIEW
it is showing this error
i have attached the error image.
Thank you.
(1,157 Views)
