Hello NI Community,
I’m facing an issue with RS-485 communication using a USB-RS-485 converter to communicate with a CFW-11 inverter through LabVIEW. I've been struggling with Error -1073807330 and Error -1073807331 when configuring the transceiver control in RS-485 Half-Duplex mode.
Here are the details:
System Setup:
- Device: CFW-11 Inverter (RS-485 2-wire communication)
- LabVIEW: Version 21
- Driver: NI-VISA, communicating through a USB-RS-485 converter
- Protocol: Modbus-RTU
- Goal: Establish communication to control the inverter and send commands like start/stop, speed reference, etc.
Issue Description:
I’m consistently encountering the following errors:
- Error -1073807330: VISA (Hex 0xBFFF001E) - "The specified state of the attribute is not valid, or is not supported as defined by the resource."
- Error -1073807331: VISA (Hex 0xBFFF001D) - "The specified attribute is not defined or supported by the referenced resource."
What I’ve Tried So Far:
RS-485 Mode Selection:
- Tested all available modes: Wire4, Wire2-EchoDTR, Wire2-CtrlDTR, and Wire2-Auto. Based on the inverter’s configuration, Wire2-Auto should be the correct one, as it is a half-duplex 2-wire communication without the need for DTR control.
VISA Settings:
- Configured the baud rate, parity, stop bits, and data bits as specified in the CFW-11 manual.
- Flow Control: Set to none, as the inverter doesn’t require RTS/CTS or DTR/DSR control signals.
- Termination Character: Disabled, since Modbus-RTU uses time intervals to mark the end of messages, rather than characters like
\r\n
Drivers:
- Verified that the USB-RS-485 driver and NI-VISA are up to date.
Error Location:
- The error occurs at the VISA Property Node in the RS-485 Transceiver Control.vi, specifically when setting the RS-485 mode and transceiver control attributes.
Questions:
- Is there a specific configuration or workaround to resolve these errors when using RS-485 Half-Duplex in LabVIEW?
- Could this be related to the USB-RS-485 converter driver, or is there a deeper VISA issue with attribute handling?
- Has anyone successfully established communication with the CFW-11 or similar inverters using Modbus-RTU via RS-485 in LabVIEW? Any specific configuration tips would be greatly appreciated!
Additional Info:
- I've already disabled attributes like DTR/RTS control and tested with a range of configurations, but no luck so far.
- The converter seems to function correctly in other basic serial applications, so I’m leaning towards a specific configuration issue in LabVIEW.
I gonna add the manual
Thank you in advance for your help!
