Populate Combo Box with File Names in a Folder
I want to have a Combo Box or drop down menu for a user to select a filename that exsists in a specific folder.  I don't want the user to have access to various folders.  I want them to be limited to the files in a specific folder.  I attached a screenshot of an example of what I want the finished result to be with the Combo Box displaying the files in a specific folder.  The files in the folder will change in the future so I want the Combo Box to update each time the vi is executed.
Nathan
(4,566 Views)
You can do something like the photo attached. This will grab a list of the files in the folder and list them in the combo box.  The property node used is the combo box/strings.
-Matt
(4,541 Views)
Use List File Function to get the files under specified folder and using property node of combo box (Property Name:Strings) display the Listed Files
(4,461 Views)
