Combo box with search memory
I need to make a combo box that you can use to search, which remembers the last N amount of searches. It should also be able to remember in between runs and therefore I am okay with a file storage of some sort. I'm not sure of how to implement this however. Any help is much appreciated.
(3,055 Views)
Needs more information on your requirenment.
(3,008 Views)
Hi an123,
A combobox holds an array of strings. You need to create this array of strings on your own: each new "search item" should be added to this array. Then limit the array to N elements…
You need to save this string array to a file at program shutdown. At program init state you read in the file and populate the combobox again…
(2,991 Views)
