Poperty Node System session -> Hostname responding with DNS name?
Hi there,
in the attached snippet, the Poperty node will reply with the hostname (i.e. "HelloWorld") when deployed from the development GUI - which is correct - and with the DNS name (i.e. "HelloWorld.local") when deployed stand-alone to the RT system (sbRIO 9627 in my case). Is this an intended behaviour? If yes, why would I want the property "hostname" to not reply with the hostname? How do I retrieve *only* the hostname?
TY!
(3,468 Views)
If you "get help" for the Hostname property, you'll see "Specifies the requested hostname for a remote system or network device.  This may or may not be the same as the DNS name".
You've discovered that for your sbRIO RT system, there's a ".local" tag on the end.  Getting rid of that "known" tag is a simple matter for a String function (I'd probably use "Scan from String" with a format of %s.local, but I'd test it to make sure it worked as I wanted).
(3,415 Views)
Thanks Bob.
So indeed it is a non-deterministic behaviour how the hostname property will respond? ... (!!) ... A property with "may or may not be" as description is far from being a helpful property to be very honest.
Regarding the workaround of deleting the ".local" part: Is this deterministic? Will the ".local" attachement be the same for other sbRIOs? Background: I am planning to mass-deploy this on a number of systems, which should all react to different config files according to their hostname. If there is a better way to do this, *PLS* let me know. 😉
TY and best regard,
Peter
(3,375 Views)
