Poor CCD Image Quality
We are acquiring images from a CCD camera in Labview using NI-IMAQ Snap.vi.
We end up with pictures that have many lines running through them (see attached).
Are there parameters that we can change such that we will end up with a clean, and continuous image?
Thanks.
-Tim
(3,301 Views)
What is the camera that you are using? Are you by chance getting a bayer coded image?
(3,285 Views)
Dear timjm,
This looks a lot like a RAW Image, I recommend you check if it is by using a program to convert it to a standard file format as we can't display RAW images correctly. There are several free programs available, I know about fitswork for example. I used it before but I don't know if it is available in English. But as I said, there is a lot of free software available.
good luck
Florian
Windows XP Professional, Labview 9
(3,276 Views)
1. We are using a Sony CCD camera that is utilized for security purposes. We chose it for its small size.
2. We are capturing the image as a png using *.vi in the NI IMAQ toolbox.
3. How do I know if it has a bayer process applied to it?
Thanks for the help!!!!
(3,244 Views)
Hi Timjm,
As far as your question about whether your image has been Bayer-encoded, take a look at this article
If it is returning a bayer-encoded image, you'd most likely have this information in the camera manual.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(3,208 Views)
