Polynomial
Hello!
Using line profile, i've obtained a curve representing the trend of pixel on an image, now i want to apply to this curve a polynomial to get a more linear trend eliminating the disturbs; but before doing this i have to select(interpolate?) some points of this curve(this points will be the input of my polynomial). How can i do this?
Message 1 of 9
(6,248 Views)
In the mathematics palette, there are multiple polynomial functions for finding roots, evaluating polynomials, polynomial curve fitting, etc.
aputman
Message 2 of 9
(6,228 Views)
Since this is in 2D a plain polynomial will not work since the coordinates can overlap (e.g. the curve could zig-zag up giving multiple y for a given x and multiple x for a given y.
If you have x and y as a function of time, you can create two polynomials x(t) and y(t) and create a parametric graph of the interpolated curve. The polynomial itself will do the interpolation. I don't understand why you think you need to pich extra points.
Message 3 of 9
(6,222 Views)
So to enter the data obtained with the line profile in the polynomial how should i do?
Message 4 of 9
(6,207 Views)
What datatype is the "line profile"? Can you attach some typical data?
Message 5 of 9
(6,203 Views)
I have to connect the line profile with the polinomial. The "untitled 4.vi" is a draft and i don't know how to connect the two parts.
Message 6 of 9
(6,189 Views)
Your attached code does not contain any data.
Message 7 of 9
(6,173 Views)
The data are the points that i have to extrapolate from the curve given by the line profile and that are the inputs of the polynomial. That was my first question
Message 8 of 9
(6,169 Views)
Accepted by topic author IlDama
Again, your VI as posted contains no data.
You can use "polynomial fit" to get the coefficients then use "polynomial evaluation" to calculate the function for an arbitrary x ramp.
Message 9 of 9
(6,158 Views)
