Polynomial's application
Hi everyone,
using Vision(as you can see in the picture below) i arrived, by the application of two filters, at this final distribution. My aim is, using Labview, to apply at this distribution a polynomial to obtain a curve without disturbs(the distribution is shown in the histogram). How can i do it?
(3,447 Views)
Hi Paino 19,
you should be able to get the histogram from the Vision Assistant Express VI, and from there you can use the interpolation function you need from the Palette -> Mathematics -> Fitting or Interp & Extrap.
Hope that helps!
CorraDIT
(3,374 Views)
Ok thanks and you know how i can get the histogram? With the line profile? Below is what i have done till now.
(3,357 Views)
Hi Paino19,
attached you can find the code and some screenshots of what you should do. Hope it helps.
(3,349 Views)
Go to Help-> Find Examples-> search for Histogram and you should be able to do it with line profile.
Edit: There's line profile example also you can check with.
uday
(3,327 Views)
