Polynomial Equation
Hi
 I have a polynomial equation
y= -0.058x^2 + 60.42 x - 3686
 Which polynomial vi  I can use of getting the value of y by varing x
 Thanks in advance
  with regards
  DK
(3,209 Views)
You can use the expression node
Expression Node
Owning Palette: Numeric Functions
Requires: Base Package
Use the Expression Node to calculate expressions that contain a single variable. The following built-in functions are allowed in formulas: abs, acos, acosh, asin, asinh, atan, atanh, ceil, cos, cosh, cot, csc, exp, expm1, floor, getexp, getman, int, intrz, ln, lnp1, log, log2, max, min, mod, rand, rem, sec, sign, sin, sinc, sinh, sizeOfDim, sqrt, tan, tanh.
In your case :
Greetings from Germany
Henrik
LV since v3.1
(3,198 Views)
Polynomial Evaluation VI
(See also this idea for some perspective :D)
(3,182 Views)
Or you could use LV primitives.
Lynn
(3,147 Views)
