Poll: What LV operators do you use most frequently?
After sharing my idea of a Quick-Drop Tutor I thought;
I may make for an interesting form of competition if we had a common set of short-cuts and could compete virtually to see who could QD the fastest.
But then the question came up "Do we use my short-cuts or who's?
So to feed this idea I would like others to reply with their favorite operators in order of preferences. We may be ale to find a common-set of operators that we all use. This could be the basis of some freindly gaming but also may serve as the standrads that ship with future LV versions.
So please post your favorites.
If you like someone elses list, give them a Kudos and we can factor that in as a multiplier for those lists.
Thank you for the help!
Ben
Message 1 of 9
(3,302 Views)
* denotes non-default values
Crtl+H (Help)
Crtl+Shift+H (Help for this vi)*
Crtl+Shift+V(View VI Heirarchy)*
Crtl+Shift+!(View Errors)*
Crtl+*/Crtl+Shift+*(Save/Save All)*  (it made more sense than S to me since the dirty dot is *)
"Should be" isn't "Is" -Jay
Message 2 of 9
(3,269 Views)
My shortcuts are now graphical, and are equal to the icons themselves. Smiley Happy
To answer your question I used my code to analyze how frequently I use LV functions (What?  You mean everyone doesn't do this?)  I have this list based on my code posted to the LV example challenges.
1. Property Node (scripting heavy list)
2. Case Structure
3. NamedUnbundler (Unbundle by Name for you non-scripters)
4. Invoke Node
5. For Loop
6. Bundler
7. Build Array ("Built Array" for altenbach Smiley Surprised )
8. Format Into String
9. Comparisons (did not hone in)
10. Index Array
As to Favorites:
1. Get/Set Variant Attribute
2. Match Regular Expression
3. Search and Replace String
4. Compound Arithmetic
5. Feedback Node (hates Variants Smiley Mad, wasted a lot of time with that one)
6. Type Cast
7. Property/Invoke Node
8. Matrix Size
9. PNG Data to LV Image.vi
10. Stacked Sequence Structure
Message 3 of 9
(3,264 Views)
Being stuck with good old 7.1, my own plugin for Ctrl+N (in the LAVA CR).
Felix
Message 4 of 9
(3,259 Views)
My Quick-Drop shortcuts:
cs = Case Structure
u = Unbundle By Name
fs = For Loop
ws = While Loop
se = Select
bb = Bundle By Name
fst = Format Into String
pn = Property Node
in = Invoke Node
Most/all of these are Darren's.  I have more, but don't use them often enough to list them.  Your Quick-Drop tutor will help me learn more. Could I suggest making it independent of the operators and providing a mechanism for each of us to define our own shortcuts?
Darin.K made me laugh, again.
Jim
Message 5 of 9
(3,228 Views)
My Quick Drop shortcuts are posted on the Quick Drop Enthusiasts group, but here are the ones I use regularly. Ones in bold I use several times a day. In general, I went with the first thing that came to mind when I first created the shortcut years ago, and having been using them for years, muscle memory just takes over:
ac - Array Constant
ad1 - Increment
as - Array Size
athc - Path Constant
ba - Build Array
bath - Build Path
bbn - Bundle By Name
bc - False Constant
car - Compound Arithmetic
cc - Cluster Constant
ccat - Concatenate Strings
cr - Close Reference
cs - Case Structure
csc - Class Specifier Constant
cv - Current VI's Path
dds - Diagram Disable Structure
dfa - Delete From Array
dv - Divide
ea - Empty Array?
ecc - Error Cluster Constant (new in 2011)
eq - Equal?
eqz - Equal To 0?
erg - Merge Errors
estr - Empty String/Path?
estrc - Empty String Constant
evstr - Event Structure
ex - Multiply 😉
fs - For Loop
fss - Flat Sequence Structure
fstr - Format Into String
geq - Greater Or Equal?
geqz - Greater Or Equal To 0?
gr - Greater?
gz - Greater Than 0?
leq - Less Or Equal?
leqz - Less Or Equal To 0?
mp - Match Pattern (have to move my left hand over for this one)
nan - Not A Number/Path/Refnum?
nc - Numeric Constant
ndx - Index Array
neg - Less Than 0? 😉
neq - Not Equal?
neqz - Not Equal To 0?
nes - In Place Element Structure
nv - Invoke Node
qr - Quotient & Remainder
ras - Replace Array Subset
rn - Property Node
s1d - Search 1D Array
sath - Strip Path
sav - Select a VI...
sb - Subtract
sb1 - Decrement
sc - String Constant
se - Select
srt - Sort 1D Array
sss - Search/Split String
tc - Tick Count (ms)
tcase - To Lower Case
trav - Traverse for GObjects.vi
tsc - To More Specific Class
ubn - Unbundle By Name
vr - Open VI Reference
vtd - Variant To Data
wat - Wait (ms)
ws - While Loop
Message 6 of 9
(3,218 Views)
Now that I'm in front of my computer, I can look at my list.  These are more of the ones I frequently use:
ai = Index Array
ac = Array Constant
ba = Build Array
sc = String Constant
nc = Numeric Constant
bc = Boolean Constant
dd = Diagram Disable Structure
jki = guess Smiley Wink
jk = customized version of above
w = Wait (ms)
Jim
Message 7 of 9
(3,185 Views)
I have similar ones as everyone else
ac - Array Constant
ad - Increment by one
as - Array Size
There are others, i will post as more come to mind
Message 8 of 9
(3,176 Views)
Thanks to all that replied!
These list start to show how we think about the operators differently. It appears those that know the formal names go with abreviations while that is not that norm for all. Since I can't look inot your heads to know how you came up with your abreviations, I mention some of mine.
First!
I don't know the names of all of those operators. I know what they look like and can remeber where I last found them some my QD short-cuts reflect that fact.
a + generally the operartors for arrays.
ag Array Get ... index array
as Array size
sf Structures For loop
bt boolean true
But then I ran into issues keeping the short-cuts below two characters and conflicts between the palettes so I resorted to old scholl stuff
va VI server Attribute node ... proprty node
bv Boolean OR
My most used are bold
QuickDropDiagramShortcuts="
aa:Initialize Array
;ab:Build Array
;ac:Array Constant
;af:Search 1D Array
;ag:Index Array
;ar:Replace Array Subset
;as:Array Size
;ba:And;
bf:False Constant
;bt:True Constant
;bv:Or
;cb:Bundle By Name
;cd:Not Equal?
;ce:Equal?
;cez:Equal To 0?
;cg:Greater?
;cge:Greater Or Equal?
;cgez:Greater Or Equal To 0?
;cr:Unbundle By Name
;cs:Select;cv:Less?
;cve:Less Or Equal?
;cvez:Less Or Equal To 0?
;ea:Add
;eav:Mean.vi [NI_AALBase.lvlib]
;ec:Increment;ed:Divide
;eq:Quotient & Remainder
;es:Subtract
;et:Not
;ev:Decrement
;ex:Multiply
;fb:Build Path
;fc:Current VI's Path
;fs:Strip Path
;qc:Obtain Queue;
qd:Dequeue Element
;qe:Enqueue Element
;qr:Release Queue
;sc:Case Structure
;se:Event Structure
;sf:For Loop
;ss:Flat Sequence Structure
;sta:Concatenate Strings
;stc:String Constant
;stt:String Length
;sw:While Loop
;tg:Get Date/Time In Seconds
;tw:Wait (ms)
;va:Property Node
;vc:Open VI Reference
;vd:Invoke Node
;wb:Build Waveform;"
Now as far as my Quick-Drop Tutor...  I'll have to find it! Once I learned the short cuts...
Take care,
Ben
Complet line from ini follows
QuickDropDiagramShortcuts="aa:Initialize Array;ab:Build Array;ac:Array Constant;af:Search 1D Array;ag:Index Array;ar:Replace Array Subset;as:Array Size;ba:And;bf:False Constant;bt:True Constant;bv:Or;cb:Bundle By Name;cd:Not Equal?;ce:Equal?;cez:Equal To 0?;cg:Greater?;cge:Greater Or Equal?;cgez:Greater Or Equal To 0?;cr:Unbundle By Name;cs:Select;cv:Less?;cve:Less Or Equal?;cvez:Less Or Equal To 0?;ea:Add;eav:Mean.vi [NI_AALBase.lvlib];ec:Increment;ed:Divide;eq:Quotient & Remainder;es:Subtract;et:Not;ev:Decrement;ex:Multiply;fb:Build Path;fc:Current VI's Path;fs:Strip Path;qc:Obtain Queue;qd:Dequeue Element;qe:Enqueue Element;qr:Release Queue;sc:Case Structure;se:Event Structure;sf:For Loop;ss:Flat Sequence Structure;sta:Concatenate Strings;stc:String Constant;stt:String Length;sw:While Loop;tg:Get Date/Time In Seconds;tw:Wait (ms);va:Property Node;vc:Open VI Reference;vd:Invoke Node;wb:Build Waveform;"
Message 9 of 9
(3,099 Views)
