Polar Plots
Morning/Evening Gurus (*delete as appropriate),
Is it possible to generate polar plots like the one in the attached? I have three inputs, a direction, a radial position and 3rd value for the colour scale (wind direction, windspeed then a gas pollutant from a weather station). I am basically looking for a Labview equivalent of Openair, if that means anything.
Thanks in advance
"When I read about the horrors of drinking, I gave up reading"
Message 1 of 12
(4,827 Views)
I am sure you could just use an intensity graph and map your data into the grid accordingly Using interpolation for missing grid points..
You can use "plot images" feature to overlay the circular scales, etc.)
Similarly, you can use a 2D picture indicator.
Do you have some typical data?
Message 2 of 12
(4,808 Views)
Either way, you need to map your data into a rectangular grid (which is also the case of your example images). For an example of overlaying grid lines and markers, have a look here.
Message 3 of 12
(4,789 Views)
Hi All,
Thanks for the info,and sorry for the slow response in replying. I was out of office last week.
I'll have a look at the thread and also try and post some data as an example.
Paul
Message 4 of 12
(4,661 Views)
Got some data together in between teaching undergrads! This would be the sort of thing, with a signal, a radial position and a direction. Would this work on your example code?
Message 5 of 12
(4,612 Views)
Hi Pablo,
Something like this:
Now you need to implement an interpolation algorithm to "fill" the blank space between your data samples…
Message 6 of 12
(4,594 Views)
the easiest way is to accumulate a 2d Histogram with rectangular or square 'bins'
Spoiler
Message 7 of 12
(4,516 Views)
Message 8 of 12
(4,513 Views)
You could check this toolkit out
https://www.vipm.io/package/heliosphere_research_llc_lib_advanced_plotting_toolkit/#:~:text=The%20Ad....
I don't know if it will solve your problem but it has some handy plots you can make.
Dan Shangraw, P.E.
Message 9 of 12
(4,487 Views)
it is common to smooth the flat square bin with a 2d Gaussian Kernel as shown here:
https://forums.ni.com/t5/Machine-Vision/gaussian-filter/m-p/2443278#M38836
Message 10 of 12
(4,462 Views)
