Point by Point Values Incorrect
I am using a loop that gets data every 10 seconds or so (Ends up being a little more, but that doesn't matter.), and each time it gets data (temperature), it goes through the Point by Point Standard Deviation VI in order to produce a cumulative standard deviation and the mean. Previously, I was using the Point by Point Mean VI to get the mean, but learned the Standard Deviation VI had the mean included.
My wired terminals are x, standard deviation, mean
Unwired: sample length, initialize, error
I ran the VI overnight for a total of about 18 hours, where it collected every 10 seconds (6690 data points). The temperature that was read started at about 27 °C and cooled to 25 °C and then was held there. On the front panel, the reported average temperature (for the whole trial) was 24.977 ± 0.017 °C, which did not seem correct to me. So I imported the data into Excel and used "=AVERAGE()" and "=STDEV()" to get a value of 25.860 ± 0.774 °C.
Why is there a discrepancy in these values? The only thing I can think of is that the Point by Point Standard Deviation VI reset itself, but cannot think of why. Maybe because I did not wire any value to the "sample length" terminal, but I assumed that it would use the whole sample when unwired.
(3,695 Views)
Accepted by topic author Quevvy
Actually, the function is doing exactly what it is supposed to.  If you read the documentation, you will see that the VI only holds so many samples to do the calculation on (default to 100).  So it actually did a moving average/std deviation.  From the help:
sample length is the length of each set of incoming data. The VI performs computation for each set of data. The default is 100. When you set sample length to zero, the VI calculates a cumulative solution for the input data from the time that you called or initialized the VI. When the sample length setting is greater than zero, the VI calculates the solution for only the newest set of input data.
So what you really want to do is set the sample length to 0.
(3,680 Views)
 I looked at that help file, but I must have missed that default value part.  I thought that not wiring it was the same as setting it to zero, but now I know! Ok thanks!
(3,675 Views)
