07-22-2019 09:03 AM
Ok, first I am aware of the benefits of using OOP.. but for this task I can't use it. I know this is a can of worms but here we go.
Here is and example of what I am trying to accomplish, look the Queued Message Handler with continuous Data Acquisition (Create Project -> Templates -> Continuous Measurement and Logging). If you were to take the lvlib for the Acquisition (Acquisition.lvlib), make 2 copies (say one is used run System 1 and the other is to run System 2) giving each a unique name, how would I load them dynamically at startup? (going to try to asynchronously launch the main ...)
Put your mind at ease, I will not be using the Acquisition.lvlib.. well at least not in it's current form.
I have been searching here a LavaG but everything I have found is based around OOP.
So in summary:
1. How do I launch a lvlib (or something similar) dynamically?
2. Do I need to do anything special for the build of the lvlib for development / deploy phases?
Thanks everyone, Ryan aka R^2
07-22-2019 09:20 AM
@R^2 wrote:1. How do I launch a lvlib (or something similar) dynamically?
You don't. You launch a VI inside a library. The VI has a full name\path, including the library.
Yes, you should make sure everything that is needed by the library is available in the executable.
You might want to look into packed libraries... It's this problem they are trying to solve. With mixed results, but better then the alternatives, AFAIK.
07-22-2019 10:29 AM - edited 07-22-2019 10:32 AM
This is a pain without using OOP. Why is it restricted?
I think without using OOP the way you would want to do it (the easiest off the top of my head) would be like my small example below (its not launching something but is a demonstration). You would dynamically create the path to a vi using the different PPL's. You then launch that vi, set the controls, and run it. Then you read back the controls to get the values back. You can also open front panels and other things this way.
Just wanted to add, another vi that might be useful is called "Get Exported File Path.vi"
07-22-2019 11:10 AM
They have given multiple reasons but I think it boils down to a previous developer using a different language did a project for them using it that doesn't really work and no one else can now use or modify... I know this is going to be painful initially...
and
So like most people do subpanels on a UI...
What format should I use so the modules are not compiled into the main application?
07-22-2019 11:23 AM
@R^2 wrote:What format should I use so the modules are not compiled into the main application?
You use strings and paths to open your dynamic VIs, not static references.
07-22-2019 12:23 PM
@crossrulz wrote:You use strings and paths to open your dynamic VIs, not static references.
Sorry I wasn't clear on what I was asking... thinking through what I need;
My modules need to be compiled (I don't want to give access to the source code) but I want them to be compiled separate from the main application. This should allow the module to be used as plugin to the main program and called dynamically at startup. I envision a folder of these modules/plugins that the main program is told which to use at run-time.
What format (ppl, llb, ...., something else) should I use to compile the module/plugin?
07-22-2019 12:29 PM
07-22-2019 12:41 PM
Packed Project Libraries (PPLs) are definitely what you want. As stated, they are libraries that have been compiled, something of a mix of llb and dll. As long as you are very careful about dependencies in said PPLs (ie if PPL A has to call PPL B), then they are simple to use. But if you have inter-dependent PPLs, you need to be very careful about having separate projects and maintaining relative VI calls in the builds.
07-24-2019 01:12 PM
