Plotting three variables
Hello!
I am using a XY graph to plot a time series together with some measurement data. However, I want to include a third variable in the plot. This variable is a constant (straight line), but the XY graph doesn't seems to accept more than two variables? Any idea how this can be fixed?
Greetings
Kristoffer
Message 1 of 13
(5,216 Views)
Not sure I understand what you mean, you have a plot (array of X,Y) and you also want to have an horizontal straight line on the graph?
You can either add a second plot (multiplot Xy graph) or maybe simpler to add an horizontal cursor.
Epictetus
Antoine Chalons
Message 2 of 13
(5,212 Views)
Hi Sjefsgjogleren,
                            Have a look at this:-
                            http://zone.ni.com/devzone/cda/epd/p/id/4322
Thanks as kudos only:)
Message 3 of 13
(5,208 Views)
Correct. I have a plot of array (X,Y), and want to add a horizontal straight line to the same graph.
Greetings
Kristoffer
Message 4 of 13
(5,206 Views)
Greetings
Kristoffer
Can you post your code. This should be a real simple take to complete.
Tim
GHSP
Message 5 of 13
(5,191 Views)
I have attached an image of what i try to do. From the image the time series (in datatype timestamp) that is plotted together with the measurement data can be seen. I want to add third variable to the plot (the blue numeric line). I would gladly posted the whole code, but it is to big and consist of to many subVIs so i guess there is no point.
Greetings
Kristoffer
Message 6 of 13
(5,187 Views)
Accepted by Sjefsgjogleren
Without more information, here is how I would do it.
Tim
GHSP
Message 7 of 13
(5,185 Views)
The only change I would make is to make the last plot just 2 elements (min X and Max X,  horizontal Value)- this requires very little extra data in the plot.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 8 of 13
(5,174 Views)
Or you can use a cursor to look like a horizontal line and move it to the location you desire.
Paul Falkenstein
Message 9 of 13
(5,169 Views)
But, depending of the settings chosen by the user, the new variable might not be the same every time the program is executed.
Greetings
Kristoffer
Message 10 of 13
(5,163 Views)
