Plotting spreadsheet file in waveform graph
Im trying to send an array of data to a wavegraph. the data is sampled at 500 Hz but and i read the data using the read from spreadsheet file.vi.
the only output i get is a straight line at 0 when the file has max at +0.6 and min at -0.2
any ideas?
(2,764 Views)
Please send more information . Can not help you else. But I can give you a hint. Open your datafile i wordpad. If you can read meaningfull numbers the fileformat is correct. If everything is a mess your fileformat is wrong. Also check the size of the output from spreadsheet file.vi.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,763 Views)
i solved it, sorry for not posting enough information. i needed to change the formatting of the spreadsheet.vi
(2,744 Views)
