GetTime Or Wait problem
Hi..
Time difference between two GetDate/Time calls with a wait function in between shows a lesser time taken than the wait duration specified. How is that possible? Pls see the attached VI. Any thoughts?
Thanks and regards
Chandra
(3,105 Views)
If you use "Highlight Execution", then you will see the behavior you have posted. Otherwise it has no problems.
[Edit:  Or am i missing something. Correct me if i am wrong.]
Message Edited by mathan on 12-06-2008 12:54 AM
(3,095 Views)
The get-date time function has a resolution of 16 ms. (or something like that) on Windows ,  the returned timestamp isn't fully accurate. This is an OS limitation.
Ton (if you use the Tick count you will see a wait time of 50/51 ms)
My LabVIEW Ideas
(3,076 Views)
Many thanks for the Tick Count tip.
After your reply, I found this link related to what you mentioned above:
http://digital.ni.com/public.nsf/allkb/4E12F6841016929D86257126007A9D94?OpenDocument
This leads to one more question. Is there any other way we can get the current time with a resolution of 1 ms (in Windows XP)?
Chandra
(3,064 Views)
