Plotting multiple sensor values on a waveform graph with two y axes of different scale
I want to plot five temperature sensors values and five absolute humidity values calculated from relative humidty sensors in a single graph.
Of course I can just bundle them all and display it in a graph but then scaling is not right.
I tried to build an array of both sets of values and then connected it to the graph but I am not getting it right. Is there a way to do it?
(2,264 Views)
Hi girish,
You use several charts in your VI - and no graph at all!
You need to create additional Y scales and assign each plot to a scale…
(2,253 Views)
@GerdW wrote:
Hi girish,
Hi GerdW,
I made a mistake in the description. I am actually using a chart. I tried to add one more y scale and used property node to assign the scale but it didn't work. I guess the same output as in the bottom right plot.
(2,244 Views)
Hi girish,
You can assign the plots in their context menu in the plot legend, no need for property nodes…
(2,239 Views)
Hi GerdW,
I did but still the plot looks the same 😞
I have used cluster to array and then built a 2D array to plot the waveform. Would it work this way?
I think it is plotting like this 21.57, 6.9. 21.26, 4.8... But I want each value as a different line in my chart.
(2,233 Views)
Accepted by girish_jadhav
Hi girish,
Apparently your method does not work!
Either use a cluster of 10 elements - or a 2D array of dimensions 1×10. Your 2D array of 2×5 elements does not work…
Did you read the context help of your charts to learn about the supported datatypes?
(2,231 Views)
