Plotting: Different Data Types with Timestamps
@petermotiv wrote:
Hi Ben,
Also need to preserve the Timestamp, not a sample number. So X-axis can be a TimeStamp data type?
Thanks for the help Ben!
I get the impression you did not look at the threads I linked. Take a look at those threads and download the code to see how they work.
Timestamps are the "t0" of a Waveform.
Ben
Message 11 of 15
(1,030 Views)
Yo Ben (& Others) ...
OK so getting close. .. looks like the Waveform graph may be the right guy. On right-clicking and setting properties on the X-axis to absolute time and adding in system date,
Message 12 of 15
(1,025 Views)
You still are not using the WF data type... and missing the wonderful flexibility available once you figure them out.
I realize I can only "lead a horse to water and can not force them to drink" but for your sake I am begging you sip of the sweet nectar when using a Waveform data type to plot data.
Ben
Message 13 of 15
(1,023 Views)
Hi Ben,
One of the links did not work for me (attached), but I did review the other over again. I reviewed it in the very beginning, and after the back and forth posts, this example make more sense, I mistakenly was still using XY Graphs.
I have enough info to likely figure it out from here as you mentioned lol. I will reply back to this thread once I figured it out, and place a PDF for all to review as a compile solution.
Thanks for the help,
-Peter
Message 14 of 15
(1,019 Views)
@petermotiv wrote:
Hi cbutcher,
This is a great idea, thanks. I have seen NaN(NIL/NULL): populated in front-panel, but I am not sure how to populate NaNs in a 2D Array. I see there is a method to check for NaNa in the compare palette, but to assign an NaN, not sure.
Maybe I am wrong, all software environments are different, but if you have a 2D Array, and throw down a number, it will pad zeros, not NaNs, see attached quick-try, I only place the '4' in the const int array[][]
Sorry - I didn't see this post! If you didn't find the answer already, then here it is:
You can't make an integer NaN, but for floating point values, just type 'NaN' into a constant. On LV2016 (and probably a great many earlier versions) typing 'NaN' into an integer constant will change it to a floating point constant. If you wanted to create an array of mostly NaN values, I suppose you could use the Initialize Array and/or perhaps Replace Array Subset primitives.
GCentral
Message 15 of 15
(997 Views)
