annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Plotting 2 arrays
Sorry,i think i have confused
X is separate set of points(an array) and Y is separate set of points(Another array), actually from your previous suggestions i have got the output. but for my analysis i am trying to get a waveform similar like to X values (X values plotted with time).
Messaggio 11 di 52
1.943Visualizzazioni
To plot 2 arrays vs time (AND the time points are equally spaced and thus linearly related to the array index), just built them into a 2D array and use a waveform graph for display. You are already doing this with the "SinCos" graph, right?
To change the time scaling, adjust offset and multiplier for the x-axis with a property node..
Messaggio 12 di 52
1.939Visualizzazioni
Thanks very much, I will try
Messaggio 13 di 52
1.935Visualizzazioni
Hi
I used many options but i didnt got the correct result
Actually I have 2 separate array(columns), i need to plot against each other.
for example, i say 1st array as X values and 2nd array as Y, so i need to plot against X and Y
Messaggio 14 di 52
1.909Visualizzazioni
This thread keeps going back and forth between an XY Graph and a normal graph. You've gotten advice on how to use both and if the display is not correct, then you need to provide details on HOW it's not correct. You've already been told this. Post the code that you are now using or at the very least, some images of what you are seeing now and what you want to be able to see.
Message Edited by Dennis Knutson on 03-31-2008 07:34 PM
Messaggio 15 di 52
1.906Visualizzazioni
Yeah its going in circle Knutson,sorry for that
I have attched the code.
In that u can see that I have named the two graphs as Torque and Theta, so the final plot is Torque against Theta( expected output waveform is similar to the torque signal)
Messaggio 16 di 52
1.900Visualizzazioni
Please ignore the previous mesage
In that u can see that I have named the two arrays as Torque and Theta, so the final plot is Torque against Theta( expected output waveform is similar to the torque signal)
Messaggio 17 di 52
1.897Visualizzazioni
If your phase is zero, then both signals are the same and you would see a straight line. At other phase settings, the graph is also correct based on the data you are passing to it. The way you have it wired, the x axis is torque. Verify that is what you want.
Messaggio 18 di 52
1.896Visualizzazioni
Thanks Dennis
Messaggio 19 di 52
1.892Visualizzazioni
Your code is still extremely convoluted and overly complicated. Have a look at the FOR loop in frame #2 of your useless stacked sequence structure.
As you can see from the picture you have 90% too much code! The array size, index array, feedback node and FOR loop can all be deleted without change in outcome. 😄 For some unknown reason, you initialize the feedback node as EXT, causing a coercion and extra data copies in memory for absolutely no benefit. The EXT array will be coerced again to DBL at the xy graph.
I left some notes on the picture. I recommend the code at the very bottom. 🙂
Message Edited by altenbach on 03-31-2008 10:43 PM
Messaggio 20 di 52
1.867Visualizzazioni
