Plot two signals against each other ,both having different sampling rates and time scales
Hi everyoneSmiley Happy
I have two signals say A and B. Both are in waveform format . Both signals varies with time, but have different sampling rates.
after the measurements are made, i need to plot signal A vs Signal B. How can this be acheived.
Waiting For the inner calling 🙂
(4,086 Views)
Just yesterday we had a very similar discussion here!
(4,072 Views)
thanks gerdw ,
does the method mentioned in that post works with waveform graphs also. there its xy graphs right?
(4,068 Views)
Waveform graphs require  that the data has equal spacing in the x (or time) dimension).. If you graph two random signals against time, the result will generally not be linear in x, so the answer is no. A waveform graph will not work. Of course you could use similar code to graph two different waveforms against each other, but you need an xy graph to display the result.
What kind of problem are you trying to solve?
(4,061 Views)
Hi djac,
you can adapt this to your needs! To plot signal A vs. signal B you should use  XY graphs anyway…
(4,060 Views)
Thanks for the suggestions Smiley Happy
(4,048 Views)
