Plot a 1D array and a 2D array in a single plot/chart.
Thank you for your answer.
Is there any other way to do this? Because for some cases the edge is not as uniform as it is here and I also have to export it as an image.
Message 11 of 12
(476 Views)
Another possibility would be to export an image of the 1D-plot (when everything but the plot is set to transparent) and add it to the intensity graph using the PlotImages.Back property.
Certified LabVIEW Architect
Message 12 of 12
(468 Views)
