Please suggest how to speed up data write into Excel report from template
@Andrey_Dmitriev wrote:
Looking at my instillation via the Registry and comparing this against the above screen capture, since I have the same problem as the OP does about Excel, I am missing two pieces of information:
  • The Win32 path
  • The PrimairyInteropAssemblyName
I suspect that the Win32 path is the one I need, but I use Excel so little now with 2021 32-bit (and have access to 2023 Q3 which displays the Excel 16.0 Object Library as a selection) that this isn't a big issue for me. If I ever need it, I just navigate to the EXE.
I did not run the file that was offered.
Message 21 of 23
(601 Views)
I believe that this is certainly on target for this thread.  Now, I'm no registry expert, but browsing through I found an entry in TypeLib for win64, but no entry for win32.  So, is it as simple as adding some entry for  a win32 call to the Office16 EXCEL.EXE?  It seems like even if it is able to point to the EXCEL.EXE that it still might look like it's working, but might be an unstable call from a 32bit environment.
Message 22 of 23
(513 Views)
I would suspect that, yes, that is all you need to do. However, I never went ahead & added that entry in so I cannot verify if it worked or not or even if something corrupted.
Message 23 of 23
(463 Views)
