Vision FPGA, LowPass Filter, 8 parallel paths, funny beatings in the result.
Dear Professionals,
I hope you can help me with the following problem.
I have a linear CLink camera (Basler spL 4096−140km), which is connected to NI PXIe-7976R module (via NI 1483 Camera Link adapter), installed into PXIe-1095 chassis.
Camera is set to acquire a single line image on external (50 kHz) trigger.
After acquisition is done, pixel values are transmitted to the FPGA module (PXIe-7976R) in 4 pixels portions per single 80 MHz clock tick (the code is placed into a SCTL).
My goal is to apply a lowpass filter to the image while it is being transmitted and make a plot - Pixel value vs Pixel Index.
As I use IMAQ FPGA Camera Link 4 Tap 12-Bit.vi (standard Vision FPGA library), before proceeding to the next code step, the 8 pixels are accumulated.
So, in fact I have a transmission of 8 pixels on each second clock tick.
To design lowpass filter I used Digital Filter Design toolkit. So, with it I get a *.fds file (in a fixed point representation).
Afterwards, in FPGA project I use IP Generator, to generate a sub-vi, which I use then in my FPGA vi code.
In IP Generator I chose the above filter file to load (See Fig. 0) and then in "More Options" I use "Inside SCTL" and set Number of parallel data paths to 8 (Fig. 1).
So, I have the code and filter working (in general) but the resulting plot shows some regular beating after every 8 pixels (Fig. 2).
Do you have any idea, where this comes from? Which parameter I have to change?
Thank you very much in advance.
(733 Views)
It's hard to comment on the result of code when we don't have any code....
(713 Views)
Well, I expected such a question 😀
But hoped one can guess the design of the code 😎
So, attached is the fpga vi code I mentioned.
(701 Views)
The content of the VIs is also very important....
(697 Views)
I wonder if your filter is detecting a moiré pattern ...  Hard to say without seeing the image, and I'm not enough of an "image" person to suggest how to compensate for this ...
(660 Views)
Well, as it is a single line image, one can consider it as an analog signal but passed through the filter in 8 data points portion.
(650 Views)
