Please help...USRP not detected
my laptop network adapted is Realtek family which supports up to 100 Mbps
but the USRP ethernet cable is gigabit
so it's not detected by my laptop
what can i do
(3,306 Views)
You need to meet the hardware requirements.  Software-defined Radio necessarily runs at "radio-like frequencies", so if the NIC in your laptop (and possibly your laptop, itself) is not fast enough, you'll need to get better/faster hardware.
BS
(3,277 Views)
And please start posting to the usrp board like you've already been told.
(3,270 Views)
i am sorry denis but it's just really urgent
so a switch 10/100/1000 will solve the problem or not ?
(3,256 Views)
I think what Dennis was trying to tell you is that USRP is a pretty technical topic, and you are more likely to find "experts" on the USRP forum than on the general LabVIEW forum.  As I understand it, the USRP standard specifies pretty high transfer rates between the USRP hardware and the Host -- if your Host does not meet the minimum requirements, it probably will not work.  However, I am not an expert on this topic -- go ask on the USRP forum here.
BS
(3,230 Views)
