Please ADVICE.
Hello.
I have DAQCard-1200 and LabVIEW 5.0.1f.
I should measure resistance in range 100 - 1000 kilohms.
Can I do it? Please advice me. Can I use +5V from pin 49 in my DAQCard for
this task?
Is circuit (see attachment) will be work?
Ohm's law.
Thank you.
Vadim Gnatkovsky.
[Attachment circuit.bmp, see below]
[See first answer for additional information]
(3,364 Views)
[Attachment(s) for question]
(3,364 Views)
"Vadim Gnatkovsky" wrote in message
news:38934d0a@newsgroups.ni.com...
> Hello.
> this task?
> Ohm's law.
> Thank you.
> Vadim Gnatkovsky.
The circuit you have is wrong. Use something of the form.
+5V--Ra--Rb--GND
Connect ACH0 between Ra and Rb. Call its measurement V0
Ra=known resistor
Rb=unknown resistor.
I=5Volt/(Ra+Rb)
Rb=Vach0/I
or
Rb = (V0 * (Ra+Rb))/ 5volt
Rb = ((V0 *Ra) / 5volt) + ((V0*Rb) /5volt)
(1-V0/5volt) * Rb =((V0*Ra)/5volt)
Rb=(V0*Ra)/(5volt*(1-V0/5volt))
For this to work you should
check that
Imax=5volt/Ra
is less than the maximum current that the +5volt supply can source.
-Robert
(3,364 Views)
