Placing control values based on Label from other VI
    I have two independent VIs, VI-1 and VI-2. VI-2 has a number of controls and indicators and VI-1 needs to place the values in controls and get values from indicators from VI-2. But only thing that VI-1 knows is the label names of controls and indicators of VI-2. Is there a way to implement the logic for placing the values in controsl and get values from indicators based on label from other VI?
Message Edited by 12345qwertt on 01-04-2010 04:05 AM
(2,724 Views)
Yes that's easily possible, open a reference to the other VI and use an invoke node to get (or set) the values:
The only thing you need to make sure is that the datatypes match, and that you have access to the remote VI.
Ton
My LabVIEW Ideas
(2,717 Views)
Thanks alot for your reply.....
(2,709 Views)
