Ping from RT Target
Hi!
I've an application running on a RT Target that needs to perform periodic checks on devices that should be connected on the target subnet.
Is it possibile to perform a ping from a RT Target?
thanks in advance for any suggestion,
Marco
(4,033 Views)
Yes its pretty simple try the attached VI.
Good luck.
(4,027 Views)
Thanks for your reply!
Strictly speaking what you propose is not a true ping, that is based on Internet Control Message Protocol (ICMP).
Anyhow should be equivalent most of the times.
I've also found a similar approach using UDP ping (not specifically for Labview): http://www.networkuptime.com/nmap/page4-6.shtml
Marco
(4,010 Views)
Accepted by MarcoMauri
Hi!
I've just realized that the same problem was posted here: http://forums.ni.com/t5/LabVIEW/How-to-Ping-a-network-device-from-RT-controller/td-p/1535420
the solution proposed by BlueCheese seems to work for me.
Marco
(3,992 Views)
