Pinch to zoom
i created the application which should be run on windows tab.. i want to pinch to zoom option in the application.. because it contains lot of images and datas.. just help me out..
Thanks in advance
Ragunath
(3,450 Views)
If you want to use the multitouch capabilities of a tablet, you'll need to call into the Windows API for Multitouch.
Someone has created a toolkit, available here: https://www.ni.com/en-us/shop/product/touchscreen-toolkit-for-labview.html
(blog)
(3,413 Views)
When making a touch application it is important to limit the amount of information you put on the screen, especially compared to a desktop application. You want big buttons that are easy to press, and probably not a lot of little datas that need zooming into. If you need one main graph to resize with the application, you can use a splitter bar to separate the graph. Then set it to "scale with pane" and the graph will adjust when the window size changes.
(3,373 Views)
